Super_Dave_344 Posted April 1, 2010 I was wondering if the 08 has a built in break light like the older WR's had. I know its LED but not sure if its a break light with the wires there to hook up to a rear break light pressure switch. I had a 04 WR 450f & it has a factory break light & wires there & was hoping the same is true on this one. i need to get a break light hooked up because i switched it to a street title so i could get my plate & ride more duel sport stuff and also be street legal in case i get caught ridding on a fire road in southern ohio as non street legal stuff gets fined for this.Im working on making a plate mount at the moment so any ideas on this would be nice too lol. 👍 Any info on this would be appreciated. Thanks Super Dave Share this post Link to post Share on other sites
HwyChile Posted April 2, 2010 I have the same bike and am going to do the same thing. To answer your question, yes the rear light has a brake light too that can be hooked up. Share this post Link to post Share on other sites
YZEtc Posted April 2, 2010 I'm using a Baja Designs LED taillight/brake light which has a built-in license plate holder. It's small, neat, and tidy. I'm using a pressure switch threaded into the rear brake master cylinder to activate the brake light. Share this post Link to post Share on other sites
William1 My Rides (2) Posted April 2, 2010 Yes, the 08 has a brake light. Look at the triangular plug from the tail light (in the side panel with the cdi) You'll see the third wire. Share this post Link to post Share on other sites
BazookaJoe Posted April 2, 2010 There is a brake light as stated above- I have mine connected right now. Also, the headlight has high and low beam, it's just not wired from the factory. Here is some info on where to get the connectors on another thread (Thanks William for locating the connectors). With these connectors, it should be a breeze to wire up the connections. https://thumpertalk.com/forum/showthread.php?t=849746&highlight=connectors+wiring Share this post Link to post Share on other sites
