slowxr80 Posted April 2, 2010 I'm getting the 95 kit for my 80 in the mail in a couple days and I have no idea what size jets to run in the carb. Here are the specs on what will be on the bike.. The bike is a 2000 with these mods: powroll 95 kit FMF pipe XR100 carb/boot/manifold UNI filter with mesh removed from filter housing Snorkle removed with holes drilled in airbox If someone could give me a few main and pilot jets to play with that would be great!! Thanks in advance, Nathan Share this post Link to post Share on other sites
socalxr Posted April 2, 2010 100-105 main, 38-40 pilot. Don't forget about the needle. Share this post Link to post Share on other sites
slowxr80 Posted April 2, 2010 Ok thank you. Should I just run it with the needle clip in each position and whatever position gets it running the best stick with that one? Share this post Link to post Share on other sites
slowxr80 Posted April 2, 2010 I went to a local cycle shop today and picked up a 110 main jet cuz that's the only one they had. I got a UNI pod filter too so i'll be using that. Also, is there supposed to be an air mixture screw on the 100 carb? Mine doesn't have one and I think I got a knock-off carb. Share this post Link to post Share on other sites
slowxr80 Posted April 3, 2010 BUMP..I should be getting my 95 kit in the mail today. My carb says ISO performance on it so I guess it is a cheap knock-off..Do these perform worse than the actual 100 carbs? Share this post Link to post Share on other sites
