86 cr125?
hey looking for some help i am new to the forum and also just finished rebuilding a 86 cr 125 and had a few questions..... after i heat cycled through the breakin i noticed that the bike just doesnt have much of a top end or a power band its there at times.. but mostly not. this year bike had the exhaust valve and heard that its better to block it off.....is this true?
secondly would a new set of reeds and a good carb clean take care of my problem?
thanks
jon
if anyone could point me in the right direction it would be greatly appreciated to day i disassembled the carb and gave it a good cleaning i ran the bike and adjusted the idle and the bike will load up as if the plug is about to foul and then it will pull out i have checked the plug and it seems ok it is a br8es could this problem be caused by the atac valve and how can i fix it thanks
