Crankcase KLX 250 93 to 300 97
The KLX300 cylinder will not fit into a KLX250 crankcase, if that's what you are asking. If you are asking if the right side of the 93 klx250 crankcase fits on a KLX300 crankcase, that answer is also no. For starters, the opening to accept the piston is smaller. The KLX300 cylinder skirt wont fit in the smaller opening unless you do some machine work on the case opening.
