mxkid1p Posted April 2, 2010 I am looking for the stock shock stacks on a 2010 KX450F...? Anyone have that info? Share this post Link to post Share on other sites
yam259 Posted April 2, 2010 2010 KX450F Fork: Comp: 19-32.11 28.11 26.11 30.11 28.11 26.11 24.11 22.11 20.11 18.11 3-16.25 Reb: 6-20.11 13.11 20.11 18.11 16.15 14.15 12.20 11.25 10.20 10.30 Mid Comp: 4-20.11 18.11 16.11 14.11 13.11 2-17.11 2-17.30 Base plate 3-11.25 : Mid Lift: .15 ICS: 2.2 kg/mm Spring:.48 kg/mm-971 Shock: Comp: 7-44.2 36.1 32.1 44.2 42.25 40.25 38.25 36.25 34.25 32.25 30.25 28.25 27.30 26.30 25.30 24.30 23.30 Reb: 5-40.20 30.1 40.25 38.3 36.3 34.3 32.3 30.3 28.3 26.3 25.3 Share this post Link to post Share on other sites
455 Posted April 3, 2010 2010 KX450F Fork: Comp: 19-32.11 28.11 26.11 30.11 28.11 26.11 24.11 22.11 20.11 18.11 3-16.25 Is this stack correct? Being that its a 2 stage. Share this post Link to post Share on other sites
yam259 Posted April 3, 2010 Should be. Larger comp port piston as well. According to Technical Touch catalog the 10 crf and 10 kxf both use the new large port piston. Share this post Link to post Share on other sites
karlace Posted April 3, 2010 do the front forks feel soft and bottom out on 2010 kxf450 Share this post Link to post Share on other sites
harrperf Posted April 3, 2010 It's a two stage.. and the mid valve stem is different this year as well. Share this post Link to post Share on other sites
Jusa Posted April 4, 2010 It's a two stage.. and the mid valve stem is different this year as well. Do you mean piston rod or valve body desing is different? Share this post Link to post Share on other sites
yam259 Posted April 4, 2010 The stem for the mid valve its self. It has the spacer built in I guess you could say. Share this post Link to post Share on other sites
karlace Posted April 5, 2010 so do these forks feel to soft Share this post Link to post Share on other sites
mxkid1p Posted April 5, 2010 so do these forks feel to soft No. Stock they were crazy ridged in the high speed. The low speed wasn't too bad but still not as forgiving as I would like. But the high speed straight up sucked! Share this post Link to post Share on other sites
