Cali Native Posted April 2, 2010 I am in the process of installing the Cycra side mounts on my brand new 09 drz 400 s and it seems the 2 bolt hole offsets are shy by about 1/16 or so and I probably need to auger out 1 of the holes to make it fit. I originally thought it was because the brake lever was interferring and after grinding out a little relief it is now clear the offset on the side mount needs addressing as well. I've read all the cycra threads I could find and didn't see where that was an issue. Is this above and beyond what I should be hassling or might I have a bad mount? I have the skid plate and case protectors and badly want to get the Cycra's on so I can play (more safely) inthe dirt next week on vacation. Thanks for you help Share this post Link to post Share on other sites
Lincolnlock My Ride Posted April 2, 2010 If your handle bars are a little off center in the mounts you'll come up short on one side. They just barely fit. Also, make sure you fit everything loose. Share this post Link to post Share on other sites
whyfly My Ride Posted April 2, 2010 Loosen up the bars, then get both sides started before you tighten anything up. I had to use a bit of persuasion to get mine to line up, but they fit great now. The bars will flex some to fit. Share this post Link to post Share on other sites
Debi My Rides (2) Posted April 2, 2010 +1 ^^^^^ to what he said ... 👍 Share this post Link to post Share on other sites
Erik Marquez My Rides (5) Posted April 3, 2010 Most brand Hand guards are a bend to fit deal at installation unless you are running the exact same bar, on the same bike, with the same bar positioning as the hand guard was built for. They are a general fit common design.. You adjust upon install. Share this post Link to post Share on other sites
crobi Posted April 3, 2010 If you are refering to the two holes that mount onto the front fork clamps, than I had the same issue. I had to dremel out one of the holes on both mounts to get it to fit. Share this post Link to post Share on other sites
Cali Native Posted April 5, 2010 Thanks all for your comments. Crobi yes I was referring to the 2 holes on the fork clamps and for anyone else in need an old school rat tail file made quick work of augering the hole out the little bit it needed. I also had to grind the mounting block where the front brake contacts it to get the perfect fit. No big deal all is great and they are sweet. Share this post Link to post Share on other sites
JoelH. Posted April 6, 2010 If you are refering to the two holes that mount onto the front fork clamps, than I had the same issue. I had to dremel out one of the holes on both mounts to get it to fit. Same here....... While we're on the subject, just FYI, I found that using one of those Roto-Zip brand, dry-wall cutting type, bits in the Dremel tool works great on Alum. Share this post Link to post Share on other sites
