BRYANS01 Posted April 2, 2010 on my 03 crf i just put a 488 kit and kimble valves in it, without a sparkplug in it it still fells like it has compression, is this normal i really havent tryed to kick it before without a plug in it. thanks Share this post Link to post Share on other sites
Braap91 My Rides (2) Posted April 2, 2010 You're going to have a little bit of compression "feel" since as the piston is moving up and compressing the air it is only able to escape through the plug hole. There is no way to tell if it has good compression until you close the system off i.e. install spark plug or better yet a compression guage. Share this post Link to post Share on other sites
BRYANS01 Posted April 2, 2010 thanks for the reply i was only cranking it over to make sure everything was spinning free before i fire it up and literaly it feels like there is a spark plug in it you can hear it sucking air from the carb and blowing it out the exhaust as well as the plug hole, i called honda and they told me that its normal and the motor will not spin freely even without a plug it, just seems wierd to me, my old 426 if i held the compression release in there was almost no feel of compression. thanks again Share this post Link to post Share on other sites
frdbtr My Rides (2) Posted April 2, 2010 You are going to get tension from the valves and cam. You are still blowing all your compression out the spark plug hole, it is just stiff when it is opening the valves. Share this post Link to post Share on other sites
BRYANS01 Posted April 2, 2010 ok cool thanks for the help i just didnt want to start it up and cry 👍 Share this post Link to post Share on other sites
XC-Kx250 Posted April 2, 2010 Double check all of your clearances on your valves and decompressioner, and double check that its timed right. Then give it a rip.👍 Share this post Link to post Share on other sites
