ReconArtist Posted April 2, 2010 Hey guys, Thanks to the help on this forum I was able to take apart the carb (FCR 39) and clean everything out and get it running again. The bike is running very well except for when I am at or near WOT. When I'm at WOT the bike either stutters or loses basically all power. Can you guys point me in the right direction as far as what I should be looking at or tweaking? Thank you guys so much. -Ryan Share this post Link to post Share on other sites
Rob H Posted April 2, 2010 Possibly water in the fuel... Share this post Link to post Share on other sites
ptgarcia My Ride Posted April 2, 2010 What is your jetting and mods? Could be lean or rich on the main jet. Share this post Link to post Share on other sites
ReconArtist Posted April 2, 2010 Full Yosh pipe, 3x3 and FCR 39. If its lean or rich on the main jet, how would I change that? Share this post Link to post Share on other sites
npm My Rides (2) Posted April 2, 2010 Post your current jetting, the number on the needle, and clip position on the needle and people will be able to give you better advice. Share this post Link to post Share on other sites
ReconArtist Posted April 2, 2010 Well I guess my question is: The bike was running flawlessly before the carb got gummed up, and now its having that hiccup at WOT, so what could I have messed up while putting the carb back? Share this post Link to post Share on other sites
tarka Posted April 2, 2010 I would say its running lean by the way you say its "stuttering". Rich in my experience is an all out bog. You say it was gummed up? Then if you know its not running right the first thing you should be doing is looking to thoroughly clean the carb. Use brake cleaner, not carb cleaner. Take each jet out and put them in a pot and make sure you give them a bloody good clean 1 by 1. And be meticulous!!!!!!!!!!!! Share this post Link to post Share on other sites
ReconArtist Posted April 3, 2010 I did clean out each jet. Share this post Link to post Share on other sites
robb5 Posted April 3, 2010 replace the jets with the upsize corrections and remove the coast enricher. Do the Eddie mod while you are at it and you will be a happy rider with a bike that runs like it should. Share this post Link to post Share on other sites
