Rebuild xr200r?
I have an xr200, pulled the motor and i think i need to put new rings in it because it smokes like crazy all the time no matter what. I read on the forum that it gets pretty involved, what do you think it needs/ I should do??
Put the motor back in the chassis and do a dry and wet compression test, then you'll know what needs to be done. Compression gauges are cheap at Harbor Freight, get the kit with four adapters because you need the 12mm to fit the XR cylinder head.
Post the results and we'll chime in to help you with the rebuild because there are a lot of details to check when you pull the engine apart to help you decide what is serviceable and not. Not hard to do, you just need a check list.
