FCR installed ? about throttle pull cable
I got my fcr installed and have a ? about the throttle pull cable. The pull cable with the curve in it goes on the bottum. I have purchased a new stock s throttle cable with the cable adjuster bottomed out and hooking up the cable to the carb it is pulling the slide up. The wheel where the cable attaches is way off the idle screw one third open throttle. Can't be right can it?
The new throttle cable is a s model and I think what has happend is when they built the cable they got the pull and return cables backwards so the pull cable way to short so I improvised and just used a single cable, had to use the return cable with no inline adjustment but seems to be fine for now the only other cables I have is the ones off the edlebrock carb I pulled off of it, thanks for the help, that pict is the one I had been looking at when installing the cables originally but was no way I could get them set up like the pict! Thanks!
