03 cr 125 trouble
Bike will start up fine and will run fine for a few minutes but then bogs down. I put in a new spark plug and it started up and same thing happened. any ideas?
I've got an '03 CR125 too and the same thing happened to me a couple months ago. Turns out I forgot to remove the plastic bag that I usually put over the air filter when I wash the bike. It's amazing how much you learn over the years from doing every conceivable lame azz thing possible...
I just had to throw a size smaller pilot jet in my 05 cr125. It would file the plug before it could warm up. The warmer weather made it run very rich. Put a new stock plug in and try turning your air mixture screw out to lean it up and if that doesn't do it follow this to dial it in:
http://www.maximausa.com/technical/l...summer2001.pdf
Edited by honda53
It was happening to mine, my gas had too much oil in it. Kept fouling the plugs, wouldn't idle correctly, ect.
Also check your carb, jets, fuel lines, air filter...
