CR125 new model plastic on a 02 model
Just curious if anyone has tried....sure the seat is different just wonder if it would work
As I recall ,
Several people did this around 2005/6,
they fitted the later plastic to 2001/2002 cr125's,
you had to change to the later fueltank , then the plastics /( seat?) would bolt-up,
apparently you had to modify the bolt-up mount for the fuletank as they were slightly different frames..??
Try posts by Norman Foley / joe chod of that kind of era ( there might not have been the 2-stroke section then,
look under husky generally, )
good luck,
Charlie
i found out that....
you still have to use 02 shrouds...but the side panels and rear fender work...
thanks
