seat height!
hey guys my seat height on my 07 kxf250 is a bit low! is there any way i can heighten it??
Is your race sag set to ~100mm? Is your bike sprung for your weight?
would adjust the Spring Preload Adjustment! heighten the bike???
perhaps maybe I tell a little more about my self I am about an inch or under 6ft! I weight about 85 - 88kg this can fluctuate!
this is standard setting
Rebound Damping Adjuster Setting
Standard: 11 clicks counterclockwise from seated
High Speed Compression Damping Adjuster Setting
Standard: 1 3/4 turns out
Low Speed Compression Damping
from what I gather counter clockwise is softening and clockwise hardening!
so what should my settings be for my height and weight????
also what should I have as the Spring Preload Adjustment??
