Motrax Micro Bar Ends
How the hell do you see anything with them there?
I mounted them on the bars also. But under the bars instead of on top. Work well, can see around yourself pretty good. The mirrors are convex, they give a good view behind you. Not great but good.
You see enough when you lift your elbows up.🤣
I've found more compact ones, and you could actually see out of them. You will need to see them in person though. 👍
Don't look like it
But I run these
Just mounted them on the bars 👍
Where did you find those at? I like the idea of putting those in the same place just under the bars!
Local Cycle Gear
Don't look like it
But I run these
How did you fit them to the bars? Does the clamp fit round?
Like Cesar said....just lift your arm a little and look under your elbow....they don't get in your way at all in this position like under the bars.....under they hit my knees when cornering and also can be broken easier when you go done 🙂
You see enough when you lift your elbows up. :applause:
+1......hey wait...you use Cover Girl Compact Mirrors ???? :jawdrop:
Just take out the Bar end and clamp to you Bars🤣
