drz400s pipe fit sm?
hi folks..
im sure lots of people have asked this but does the drz400s fmf powercore 4 tailpipe fit the sm model?? im still bog standard with standard header on my sm..will it fit or do i need the fmf header too?
thanks!👍
hi folks..
The 'S and 'SM have identical stock exhaust. So what fits one, will fit the other.
Now, whether the powercore 4 will fit the 'S header, or is made for the larger 'E header, is something else entirely.
Either way, a slip-on is pretty pointless on the DRZ. If you want any performance gains you need a full exhaust. If you just want a louder exhaust, buy an open endcap to bolt on the stock muffler. Cheaper and easier to install than a slip-on, with pretty much the same result. (Save the stock endcap in case you need to swap it on for an inspection or somesuch.)
