paul 250x Posted April 3, 2010 (edited) hello all,i have a 2005 crf250x,that wont start off the button,unless u just twist the throttle slightly,but wont start like that all the time,it spins over then bogs down as if its full of petrol,then if u kick it it will go,i have replaced spark plug and battery and stator coil as that packed in,i u play about with the fuel air mix it desnt seem to make much difference,is there a standard setting for the fuel air mix?it has a high comp piston ad new rings just fitted,i have found if u hit the starter when u r kicking it it will start no problem,any body had this problem or similar? Edited April 4, 2010 by paul 250x not enough info put in by me, Share this post Link to post Share on other sites
