fluffing
E model,
standard set up,
just off tickover when the throttles opened slowly it tries to stall, gets better when the engine is warmer,
its not major, but i can feel it doing it, does the mixture screw need adjustment?
if so, in or out, ?
any idea,s? (exept open the throttle faster:banghead:)👍
So, when the motors cold you have some problem with throttle response, but when it warms up all is ok?
Sounds yer good to go. Don't change a thing.
no, its better when warm, not ok
if im in traffic sometimes, it causes problems stalling as i set off slowly,
it stalls quite a lot , i wonder,d if its related,
i may have the tickover too low though, someone said 1700rpm?
im used to a lower tickover on bigger bikes,im not used to a light flywheel,high revving single,so i may be causing some probs myself in traffic by not revving it high enough and having the tickover at 1200rpm?
what is meant by the term "tickover"?i've never heard that before.i'm having difficulty understanding what you've written.
tickover(england)
idle?(american?)
im gonna pull the carb today an do the eddie mod, as i can see the holes badly worn, this may cure it,
i just noticed the locktite thread for the alternator too, (happened to me 3 week ago)
i need to look on here more often:bonk:
