aloha450x Posted April 3, 2010 Has anyone done it? From what I understand I have an extra 80 watts and the 2 yellow wires under the tank are ac aux power so I think I need to install a reg and should be good to go. Will the bracket from the 250xc work on the 200? Share this post Link to post Share on other sites
Pedroski Posted April 3, 2010 Why do you think you need a fan? Share this post Link to post Share on other sites
Mike in Fresno Posted April 3, 2010 properly jetted, overflow tank of some sort, the right fluid and you probly wont need a fan. There was a thread here from CHAZMANIAN, I think it was, that shows a fan on a 300 that might help if you can find it. Share this post Link to post Share on other sites
aloha450x Posted April 4, 2010 It's jetted correctly, and rarely overheats. Only in the really nasty stuff. But I gave a spare new 4" spal fan so I figured why not. But it dies take alot to get these 2hundos to spew. Share this post Link to post Share on other sites
Mike in Fresno Posted April 4, 2010 to make it easier I would not use a thermo switch and just hard wire it to a switch, you turn the fan on n off when you think it needs it. You can use a toggle or a bar mount switch like the two way ignition curve switch. Share this post Link to post Share on other sites
