Clutch plates sticking
I have a 08 450 EXC-R 2,000 miles. Clutch plates started sticking. Pull in the clutch and put it into first gear, killes the engine unless to give it some RPM's, makes a big clunk. The plates have always stick a little but never this bad.
Bled the hydrualic line added new fluid. Disassembled the clutch and check it everthing looks good. Using Rock Oil Gear oil light. Have been using this for years, never had a problem until now.
Any Ideas???????? What do you use for the gear box?
32
I have the problem with my 07 250XCFw, cont have the problem with my 06 525exc. Some models have more of an issue. It comes down to the oil you use and warming the bike up. If it does it when its hot from being ridden then there is a problem. Other wise its a quirk to put up with. I learned to rev my 250 a little for that first shift in gear when its cold.
