Honda 400ex Posted April 3, 2010 Hey guys I took my 250 out for a short ride arond today for about 10 minutes. It ran great but seemed to be harder to shift down. Up is fine. I put the bike away right after I felt this and havent tried anything yet. Any help appreciated. Share this post Link to post Share on other sites
Honda 400ex Posted April 3, 2010 Ok I went out and checcked the tranny oil. It was green before running then I let it run and checked it per manual andit was white. Idk if thats right. Then I adjusted my clutch cable and tried. Still hard shifting down and when I pull the clutch in to turn it makes a zzt zzt noise. Please helP! Share this post Link to post Share on other sites
WALKINGWOUNDED Posted April 4, 2010 Sounds like you have engine coolant mixed in with the tranny oil. Check you engine coolant level and see if it's dropped more than normal. Have you ridden through any deep water. If not you can start your bike and warm it up, then drain the tranny fluid and refill to see if it turns white again. But keep and eye on the engine coolant level. Share this post Link to post Share on other sites
Honda 400ex Posted April 4, 2010 i havent ridden thriogh any water Share this post Link to post Share on other sites
WALKINGWOUNDED Posted April 4, 2010 i havent ridden thriogh any water Then check out the above mentioned and keep us posted. Share this post Link to post Share on other sites
Honda 400ex Posted April 4, 2010 Coolant full. No water, I checked it again and it was a greyish color. Share this post Link to post Share on other sites
WALKINGWOUNDED Posted April 4, 2010 Greyish color can be clutch wear (normal), or at worse case metal form a gear or maybe bearing (not normal). Warm it completely and let it drain for longer than normal. Then fill and keep an eye on the color and the shifting quality. Share this post Link to post Share on other sites
Honda 400ex Posted April 4, 2010 Greyish color can be clutch wear (normal), or at worse case metal form a gear or maybe bearing (not normal). Warm it completely and let it drain for longer than normal. Then fill and keep an eye on the color and the shifting quality. So why was it green when I checked it cold? Share this post Link to post Share on other sites
motodogg01 Posted April 4, 2010 So why was it green when I checked it cold? Air bubbles in the oil and any debris in the oil being re-circulated while the motor is running. Dirty, old traning oil can also cause shifting problems. Warm it completely and let it drain for longer than normal. Then fill and keep an eye on the color and the shifting quality. WALKINGWOUNDED is right. Get some clean, fresh oil in there first. Check all fluids, then test it again while checking all fluids again. Share this post Link to post Share on other sites
Honda 400ex Posted April 4, 2010 Air bubbles in the oil and any debris in the oil being re-circulated while the motor is running. Dirty, old traning oil can also cause shifting problems. WALKINGWOUNDED is right. Get some clean, fresh oil in there first. Check all fluids, then test it again while checking all fluids again. Well the oil was never green I checked again today it was the lighting. I rode it and the downshifting wasnt hard after it wartmed up. Was this the proble,? Share this post Link to post Share on other sites
