lots2learn Posted April 4, 2010 Ran it last week, no problem. Went out today and no power, no lights will not start. Battery is fully charged. Any help is appreciated... Share this post Link to post Share on other sites
reconranger Posted April 4, 2010 The starter and lights are on the fused circuit, so most likely a blown fuse. Chances are however that you will put a new fuse in, and it will blow too. Common cause is a pinched wire somewhere that has lost its insulation and is grounding out on the frame. Check the wires to the lights first. It should still push start.....so you can at least still ride it during daylight. Share this post Link to post Share on other sites
lots2learn Posted April 4, 2010 Fuses look good. Could it be the key switch? Share this post Link to post Share on other sites
