08crf250xxx Posted April 4, 2010 hey guys i need a little help. my cousin just got a kx250f a couple months ago, and the gearing is terrible for the trail riding that we do. the bike will not climb anything without stalling time after time. At first i thought it was because my cousin was new to riding, but i rode it today and it was just as bad for me. it has the stock front sprocket and a 48 tooth rear sprocket. what should i change the sprockets to in order to have a good trail bike? 👍 Share this post Link to post Share on other sites
williamsb27 Posted April 4, 2010 Your going to want to have more top end right? Try sprocketcalculator.com out. Share this post Link to post Share on other sites
the white stallion Posted April 4, 2010 You have other problems.No one else has ever mentioned this and I find it hard to believe that out of 5 gears you can't find one of them to climb a hill without stalling. First off how slow are you trying to climb a hill? Share this post Link to post Share on other sites
gasgasser Posted April 4, 2010 You have other problems.No one else has ever mentioned this and I find it hard to believe that out of 5 gears you can't find one of them to climb a hill without stalling. First off how slow are you trying to climb a hill? Yep, my 07 has stock gearing and gets up hills fine. I round you do have to use the clutch a bit (you should always have one or two fingers on the lever), but you do on pretty much most bikes. It's an MX bike not a tractor. Share this post Link to post Share on other sites
bikeride4fun Posted April 5, 2010 Most everybody seems to go to the 13/49 combo....it works great on my 07 KX250F... Share this post Link to post Share on other sites
08crf250xxx Posted April 5, 2010 all i know is ive rode all my life and have never had a bike that was so hard to ride trails with. In 1st gear the bike will not go up an incline without being almost full throttle. My crf250x will go anywhere with ease and i want my cousins bike to be the same. Share this post Link to post Share on other sites
kawibunga13 Posted April 5, 2010 for sure something else wrong.. my guess is jetting. I can lug almost stall in 2nd but it still climbs right up hills. If you're running into trouble in 1st there's gotta be something else wrong Share this post Link to post Share on other sites
D-K Posted April 5, 2010 Put on a 49 or 50 tooth rear sprocket and put in a #42 pilot jet and set the fuel screw at 2,5 turns out. And use less oil on the air filter...👍 Share this post Link to post Share on other sites
08crf250xxx Posted April 5, 2010 alright thanks guys. i'll give it a shot. Share this post Link to post Share on other sites
chadk66 Posted April 6, 2010 put a 50 on the back it will work great. Share this post Link to post Share on other sites
the white stallion Posted April 6, 2010 Maybe the clutch is bad.? Share this post Link to post Share on other sites
08crf250xxx Posted April 6, 2010 the clutch was replaced about a month ago. Share this post Link to post Share on other sites
kawasakimx8 Posted April 7, 2010 50 rear and u will love it! with a 13 front. Share this post Link to post Share on other sites
