mudbone Posted April 4, 2010 I have a 98 te610 with a BigGun header and pipe and a dellorto carb with 168 main and 60 idle jet. The bike runs fine except for a sputter just off the bottom. Acceleration is fine, but when putting at very low rpm it sputters. I tried tuning it out with the idle mixture adjustment as the Dellorto carb tuning guide suggests, setting the idle slightly high (1200 rpm), adjusting the screw to the smoothest running position, then setting idle back down. In doing this procedure I can't get a smooth run. It continues to sputter more or less wherever the screw is as if a little starved for fuel. Would changing the idle jet make a difference.Thanks for any help. Share this post Link to post Share on other sites
