2007 ktm 450 sx balancer gear
can anybody tell me how to time my balancer gear to the drive gear / crank shaft?
Ktm uses a mounting pin to hold the gear into position. But you can mark the position on the water pump.
Motor at TDC, there's a hex key screw near the pump . This is where the mounting pin is inserted. But just line up the mark on the balance gear to mounting pin hole and mark the water pump impellar.
sorry, but If I don't have marked before remotion, don't understand how positioning and timing pump gear when re- assembly outer case on engine.
