Will a 2007 motor fit in a 2005 motor ?
I bought some Works connection bash gaurds for my 05 and kept them for the 07 but needed to get some 20mm bobbins made for the bottom engine bolt as the 07 cases are narrower (if i remember correctly). apart form that i think most other mounts are the same or similar to the eye but you know that something won't fit. Ask the seller if you can try it in before you buy he may let you if you take your chassis to him.
