Rim Lock Size
I want to put a rim lock on my son's Yamaha TTR 125 front tire. It has a 1.40 front rim but I've ony been able to locate 1.60 rim locks. Will the 1.6 fit on the 1.4 rim? He's had four flat fronts in four trips to the woods. The tubes are tearing at the base of the valve stem. I'm thinking the tire is spinning on the rim under hard braking. Any other suggestions?
I've never seen a 1.40 rim lock, it's always a 1.40/1.60 rim lock.
Although I did find this, it's a CR80 rim lock, said to be 1.40
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370335232510&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=214fed1311d0a074fb670807ffd67edd&rvr_id=&ua=M*S%3F&itemid=370335232510
