use xr250 18" rear wheel
well i got the wheel on to make sure everything would work out on it, seems to be ok. couple of questions tho. first is what size tire should i get that wont rub was thinking about a 100/90 or a 110/100 and second, do i need to change the small gear to a few more teeth or is it ok to leave on there. thanks
One tooth less on the counter shaft is an almost exact match for the increased rolling radius going from a 17 to 18" wheel. I've run 13/49 with 18" wheels as well as 12/49 with a Trials tire. With the 17" wheel I've run 13/47 and 13/50.
Stay with the smaller tire, the 200s don't have enough power to take advantage of the larger tire, and there are clearance issues to the chain guard.
