XR650R cam specs
Here's the stock XR650R cam specs for anyone wanting to compare it to the Hot Cam Stage1 and two....
CAM VALVE DURATION LOBE INTAKE OPEN/CLOSE RUNNING
NUMBER LIFT AT .040" CENTERS DESCRIPTION AND APPLICATION EXHAUST OPEN/CLOSE CLEARANCE.
stock cam int. .374"lift 246° 105° 18 btc/48 abc .060"
ext. .375"lift 248° 105.5° 49 bbc/19 atc .010"
stage 1
Intake
Intake lift (mm): 9.26 = .365 lift
Intake lobe center (degrees): 109.00
Intake duration (degrees at 1mm): 254.00
Intake valve lash (mm): 0.15
Exhaust
Exhaust lift (mm): 9.21 = .362 lift
Exhaust lobe center (degrees): 105.00
Exhaust duration (degrees at 1mm): 251.00
Exhaust valve lash (mm): 0.20
Note: Divide mm values by 25.4 for inches.
stage2
Intake
Intake lift (mm): 9.57
Intake lobe center (degrees): 107.00
Intake duration (degrees at 1mm): 265.00
Exhaust
Exhaust lift (mm): 9.51
Exhaust lobe center (degrees): 103.00
Exhaust duration (degrees at 1mm): 260.00
