cyrusgsxr Posted April 5, 2010 cant figure this one out 👍 i touch the bottom of the 17mm nut at bottom of carb loads of fuel there every time ive stripped n blasted the carb twice with carb cleaner, payed particular attention to the float inlet making sure no restrictions or sticky needle syndrome double checked the float hieght was set to 9mm fitted new jet inspection O ring petcock is manual and works as should even tried running the bike until i hear bike rev up with petcock turned off to make sure not much fuel in bowl b4 i switch off my float bowl gasket looks ok still raised above the flat but beggining to suspect this is the cause what u guys thnk ?? Share this post Link to post Share on other sites
Wayward Son Posted April 5, 2010 float bowl gasket. Share this post Link to post Share on other sites
cyrusgsxr Posted April 6, 2010 cheers Eddie, also is the brass inlet hole where the float needle sits removable is there another O ring in there ?? tried to manouver it last time i had the carb apart but seemed pretty solid in there Share this post Link to post Share on other sites
