Help with a yz426f overheating
You guys are probally gonna kill me but excuss my newbiness in thumperville. I just accuired a yz426f and it runs great. I rode it today for about ten minutes. Took it down the road and then let it idle in the backyard for 2-3 minutes. At this point it began spitting coolant(blue ice) out of the overflow. Is this normal for this to happen? I have heard that you have to keep these bikes moving but this seems very weird. Is there anything that you can do to help this?(Fan or anything) I bought this for trail riding but am not sure it was a good choice if it cant idle without overheating. Help please very frustrated.
You let it idle for way to long. Always shut it off if your sitting still for more then 30 seconds or so.
wow how hot was it out? i can ride mine and sit idling for a couple minutes without any problems. just yesterday it was probably near 80 or above(it's 84 right now) and i went trail riding on our h/s practice loop(single track) and had to stop and clear limbs and what not more than a handful of times and most of the time i'd just hit neutral and let my buddy hold my bike while i moved the debris... no problems... i'm running engine ice also...
What cap do you have? I currently have the stock 1.1 on there and it will start spitting out the fluid after a pretty short period of time, 2min max. Going to pick up a 1.8 to combat the problem.
Riding in hot socal deserts.
mines the stock cap too. honestly it has yet to overheat on me... actually, this has me hoping there's not something wrong with my cooling system :thumbsup:
I just think that it is weird that you cant let it idle setting without it getting hot. Are there any solutions to this?
It's probably empty.
Keep moving, idle facing into a 10 mph wind, or use a battery powered fan.
lol, my maintenance hasn't fallen to that level just yet bro. actually i just flushed and refilled my radiators yesterday to be exact. and always keep a careful eye on all my fluids. i just don't think it's gotten hot enough here yet for me to have really overheated it. just got the yammi end of last season and yesterday was the first really hot day we've had around here :thumbsup:
i think a few minutes is way too fast. i was out at the dunes this weekend on my 400 in 80+ heat and it never spews coolant while at idle, or any time for that matter. and its full of good clean coolant with a stock cap
In most reasonable weather, they'll idle for a minute or so without a problem. What I find out a lot of the time is that "I only let it idle for a couple of minutes" was really much longer than that. If you really think of how you ride, most of the time, you don't really let it sit there that long.
I have a 1.1 radiator cap on it. Do you think thats the prob.
No, I don't.
Is it possible that I could have a blown head gasket? What should I look for? The thing runs like a scalded dog lots of compression.
Check your oil to see if it is milky and keep an eye out on your radiator fluid level.
Chances are there is nothing wrong and as gray said your "couple of minutes" may have been more like 4-5 minutes which is too long to sit and idle.
I have the stock cap on mine and have let it sit for close to 2 minutes with no radiators fluid overflowing.
Also a small pilot jet may cause it to get a little warmer than usual but that is unlikely to be your problem.
mine does it all the time when I;m going really slow. Don't worry about it. It's normal. Thats why the WR has a recovery tank.
Oil in the resivoir is normal. I have talked to people that say that there 426 has never boiled over. How do I check that the water pump is working appropriatly?
Where is the thermostat?
There is no thermostat.
Gray I think you mentioned looking under the rad cap to check for bubbles. I didny see and definable bubbles but the is alot moving around down there. Check out my video and see what you think.
Can't tell anything from that.
  • Similar Content
    • By Woody Oakson
      So I have a 2008 yz450f and I would like to add some LED lights to it to make it street legal. Mainly just a headlight and a tail light and turn signals if I need to (which where I live hand signals work).
      So where I need help is getting power from the stator to a battery. Wiring from a battery to anything else I got and understand and don't need help with (but recommendations are welcome). So my questions are.
      What type of power is coming from the stator. AC or DC? Will I need a regulator or rectifier? How do I wire something from the stator to charge a battery? What would that wiring look like? Would this stator work? Anything else I should know? Any help would be appreciated. Thank you.
    • By Samx22x
      Alright so I’m new to the site so maybe this question has already been asked. I have a 2002 Yz426f and I want a new exhaust, it has the stock header and silencer and sounds amazing but I’d like a little more from it, I know I want the fmf power bomb header and am kind of undecided on the silencer, I see on fmf’s website that their silencer will add low end and slightly take from top end and the other way around but I’m looking for increases throughout rpm range. I do a lot of trail, hill climbs, jumps, and wheelies so kind of need good performance everywhere in the rpms. My question is what silencer I should get and the jetting I should get for the carb. Thanks
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
