mikekx102 Posted April 6, 2010 Hey, I found this article on Wikipedia when i did a search for it: http://wiki.answers.com/Q/How_often_change_top_end_on_KTM_250SX "It all depends on your riding.racers change 25hrs or so.I ride every other week end 3-4 hrs,its giong on 3yrs since last top end.Buy compression tester 170psi needs top end,my compression 220.KTMs piston are forged like wisco,But austria quality.Usually bike has lost power,runs but not as peppy ,depending on compression" So, at the start its 220+PSI, and needs a rebuild at less than 170?🤣 How low should I go? 150 or what? Its currently at 192 with no carbon in the exhaust pipe, so i presume there's none in the motor either. Mike. 👍 Share this post Link to post Share on other sites
mikes300 Posted April 6, 2010 most agree once you see a 10% loss time for at least rings, then you can measure the piston clearance and make your decision, to make it easy i just do rings at 80-100 hrs, and a complete top end every other time. Mike Share this post Link to post Share on other sites
mikekx102 Posted April 8, 2010 we dont have anything to measure the piston wear with, so we'll just replace that, the gudgeon pin and small end bearing. hmm getting expensive 👍 Share this post Link to post Share on other sites
rpt50 Posted April 10, 2010 I have always heard that KTM pistons are cast, not forged. Anyway, I think the only people that could provide an "answer" to this question are race teams that have been consistently using the same parts for a long enough time to have a solid data base for when parts fail. They will develop a schedule as to the intervals that engine (and other) parts need replacing. And the answers they provide would not be applicable to regular folks, as their riders are faster, engines are tuned differently, etc. Compression readings are going to be tricky, and you would have to use the same gauge for all readings. I have 2 gauges, and they do not give the same reading on a given cylinder, and I have no way of knowing which is correct (or maybe neither is correct!). In my opinion, you can use gauges to measure relative changes, but not for absolute values, unless you have some way of verifying accuracy. I think the best thing that regular guys can do is select a nice and safe interval, and stick to it. I have always stuck to the " 1 top end per year" interval for 250s that are regularly ridden/raced on weekends. I have never found a ring gap out of spec or any other unusual wear when sticking to this interval, and it is cheap insurance for a smoker. And although I have no real data, it seems that forged pistons are more durable when surveying friends about piston failures (e.g., cracked skirts). Unfortunately, I'm about to break my own rule, as the recession has made a massive dent in our household income, so I think the current top-end in my 250 is going to have to last a while longer this time around. 1 Share this post Link to post Share on other sites
ktm300 My Ride Posted April 10, 2010 Mine was 210 new, at 170 your bike will seam to run good until you ride a fresh one, you gradually loose the snap and pull out of corners. KTM is using Vertex pistons VS Wossner, there half the price, but they also seem to have half the life. Share this post Link to post Share on other sites
fender bender 59 Posted April 10, 2010 Mine was 210 new, at 170 your bike will seam to run good until you ride a fresh one, you gradually loose the snap and pull out of corners. KTM is using Vertex pistons VS Wossner, there half the price, but they also seem to have half the life. Very well said......... After haveing the head cut and a very little porting (cleaning) I installed a new Wossner piston which give me 220 psi. Just for fun I just went and checked my bike and it now has 195 psi with about 100 hours of ride time..............YES I'm slow.... Share this post Link to post Share on other sites
kawi rider 13 Posted April 12, 2015 My 2014 250sx has about 15 hours on new piston and I haven't noticed any loss of power and it runs fine but I'm getting a reading of 90 psi, something doesn't seem right here... Share this post Link to post Share on other sites
Texasxcrider My Rides (6) Posted April 12, 2015 I did a top end on my '12 250 XC after about two years. I ride about 50 times a year for 1-6 hours and race about 4 enduros per year. Pulled the jug and it looked brand new but went ahead and tossed a new piston and rings in anyways. I religiously clean my filter though and that helps with longevity. 1 Share this post Link to post Share on other sites
KTM-548cc Posted April 12, 2015 at 15hrs everything should be practicaly new. most likely your gauge is wrong. if you have a fair amount of resistance on your kick lever then certainly your cylinder pressure is far higher than 90psi Share this post Link to post Share on other sites
Swappa My Rides (9) Posted December 28, 2018 Anyone with more insight on the new 2017+ 2-stroke KTM Husky? I've just bought a 2017 2-stroke w 22 hours on the meter. Compression test values should be close to brand new. Looking up the exhaust and in the intake, everything looks great and there is plenty of resistance on the kickstart. I'm thinking about buying a compression tester if this is a good means to keep track of when to rebuild. Obviously there are plenty of guys that get 1,000 hours for the top-end, but I run my bike hard (a lot of WOT) and like my jetting crispy, so I tend to be a bit more conservative and change parts more often than others, just to be on the safe-side. Between compression test, hours on the meter and good old rattle test, I think I should be able to read it pretty well. I'd hate to break the skirt and lunch the engine. Share this post Link to post Share on other sites
Poldies Posted December 30, 2018 IMO RPT's post nailed it. No consistency with compression tests, I don't do them. Select a realistic interval and stick with it. I'm going 100 hours on my 250 before I think about it, but I spend most of my time in the midrange. If I was wringing it out all the time I'd replace every 40-50 hours. I did a top end annually (40-60hrs per year) on my 150, which did get revved a lot, and never took out a bad piston. 1 Share this post Link to post Share on other sites
Doc Brown Posted December 30, 2018 (edited) 42 minutes ago, poldies4 said: IMO RPT's post nailed it. No consistency with compression tests, I don't do them. Select a realistic interval and stick with it. I'm going 100 hours on my 250 before I think about it, but I spend most of my time in the midrange. If I was wringing it out all the time I'd replace every 40-50 hours. I did a top end annually (40-60hrs per year) on my 150, which did get revved a lot, and never took out a bad piston. Agree 100%. Select a realistic interval and you are on the safe side. All one needs to consider is engine capacity and riding style to determine the correct changing pattern. And, what Texasxcrider said about air filter changes is really important and pays off.... Edited December 30, 2018 by Doc Brown typo 1 Share this post Link to post Share on other sites
Poldies Posted December 30, 2018 1 minute ago, Doc Brown said: Agree 100%. Select a realistic interval and you are on the save side. All one needs to consider is engine capacity and riding style to determine the correct changing pattern. And, what Texasxcrider said about air filter changes is really important and pays off.... Exactly, filter maintenance is key. 1 Share this post Link to post Share on other sites
Chas_M Posted December 30, 2018 5 hours ago, poldies4 said: IMO RPT's post nailed it. No consistency with compression tests, I don't do them. Select a realistic interval and stick with it. I'm going 100 hours on my 250 before I think about it, but I spend most of my time in the midrange. If I was wringing it out all the time I'd replace every 40-50 hours. I did a top end annually (40-60hrs per year) on my 150, which did get revved a lot, and never took out a bad piston. I do not agree with this. Compression tests are consistent and are very helpful as long as the same compression gauge is used, at least they are in my 2-strokes using the e-starter for the test. Share this post Link to post Share on other sites
mog Posted December 30, 2018 But a 2 stroke piston can show good compression just before the skirt breaks ,so it can't be used to say what condition the piston is in 2 Share this post Link to post Share on other sites
7thirtyseven Posted December 30, 2018 6 minutes ago, mog said: But a 2 stroke piston can show good compression just before the skirt breaks ,so it can't be used to say what condition the piston is in Mog, you should be out riding that 19! 1 Share this post Link to post Share on other sites
mog Posted December 30, 2018 I know ,but I'm old and a fair weather rider lol 1 Share this post Link to post Share on other sites
7thirtyseven Posted December 30, 2018 27 minutes ago, mog said: I know ,but I'm old and a fair weather rider lol I'm old too... But I'm in that desperation mode, how many riding days are left to me? Get out and ride you old fart! 1 Share this post Link to post Share on other sites
mog Posted December 30, 2018 Don't talk like that lol ,you will send me into panic mode ! I am working on the bike even if not riding it [emoji3] 1 Share this post Link to post Share on other sites
