EXC 2008 vs 2009 fork
If I've understood it correctly, the 2009 forks on e.g. 450 EXC-R are markedly better from factory than their 2008 counter part.
Does anyone know if there an easy way to upgrade the 2008 forks? When comparing the micro-fisches of the two forks, there are several minor changes (rebound piston rod/tap, rebound piston, piston ring, sleeve screw) and some major (the whole leg, inne tube)
I am about to service the forks anyway, so if it's an easy fix...
