removing kickstand and mount on 07+ WR
Yep, I did. Pick up the left footpeg mount and idler bolt from an '07 YZ. Your dealer can order it. Pretty cheap, perfect fit, and gets rid of that empty hole. 👍
Fwiw, the difference in weight between the two mounts is negligible.
If you just want to remove the kickstand, do what William1 said. If you use the YZ mount, the WR idler bolt is too long; it works fine but sticks out under the swingarm too far to look "right".
