theres a ton of play in my shift lever.
I doubt the bearing is warn. It is a needle bearing. Is the play up/down or in/out?
up/down maybe the splines are loose. Check the pinch bolt. in/out is normal. check to see the snap ring is in place on the shaft where it comes out of the motor. Large up/down play or no shifting is a problem inside the right case.
a tiny bit up and down. alot in and out I think I can see the loose snap ring but its covered in dirty oil from my cs leak. do I just take off the shift lever and get a deep set sprocked and tap the snap ring back in place??
