2000 rm250 inner clutch cover leaking
Checked the bolts they are all tight. Leak is pretty bad. It is leaking high up on the back side of the inner clutch cover case so it doesn't leak unless I run it. Why do I need to drain coolant? I know the water pump is internal on these motors but I was looking at the service manual and it doesn't say anything about draining coolant. I was hoping I could just remove the kickstarter and brake lever allowing me to slide the inner cover off and replace the gasket. The output for the water pump is on the other side of motor. I bought the bike used and the leak needs to be fixed.
