08230 Posted April 6, 2010 👍 my got my bike out to take the first ride in about 6weeks and it cranks but everytime i give it gas it spits and spudders and almost shuts off changed spark plug and set the right gap took card off not sure what i'm lookin at but it looks clean any ideas? 🤣 oh do these bikes have fuel filters? Share this post Link to post Share on other sites
rockyroad217 Posted April 7, 2010 i would check the carb, it sounds like the jets could be clogged and need a cleaning Share this post Link to post Share on other sites
cwcarter Posted April 7, 2010 Make sure your battery is fully charged. They have a dc cdi. Better yet replace it with a new one and use a trickle charger on it if sits for longer then a couple of weeks. Share this post Link to post Share on other sites
shortfellow Posted April 7, 2010 If the bike starts with the "start button" their's nothing wrong with the battery. The battery's hardest job is turning the engine over. After it starts the ignition system doesn't depend on the battery. It works off the alternator, which also charges the battery. Send the money you saved on a new battery to "The Shortfellow Foundation". LOL Share this post Link to post Share on other sites
08230 Posted April 7, 2010 the batt. is dead i have to jump it off but it runs fine at idle its just when i give it gas it craps out Share this post Link to post Share on other sites
cwcarter Posted April 8, 2010 If the bike starts with the "start button" their's nothing wrong with the battery. The battery's hardest job is turning the engine over. After it starts the ignition system doesn't depend on the battery. It works off the alternator, which also charges the battery. Send the money you saved on a new battery to "The Shortfellow Foundation". LOL Are you talking from experience or do you just know it all ? If you have a low or defective battery on these bikes they will start and idle fine but will not take revs. Share this post Link to post Share on other sites
cwcarter Posted April 8, 2010 Here's a quick video I did. Share this post Link to post Share on other sites
Rickt Posted April 8, 2010 if the battery will not take a charge you will have to start there anyway so change it. I would soak the carb in a can of cleaner for at least a few hours, then blast some carb cleaner through the jets. If you are still running stock jets think about changing them. check out the sticky for proper sizing. Good luck Share this post Link to post Share on other sites
massey1two8 Posted April 10, 2010 may be a stupid question but are you letting the bike properly warm up before you start cracking the throttle? i know my bike doesnt respond well to any type of throttle movement when its cold:ride: Share this post Link to post Share on other sites
