Jordanmaxx Posted April 7, 2010 Hey guys, need some help. I dont even know where to start looking, but here's the details. Basically, the bike runs pretty dang good: good throttle response, good pull, good over-rev. But, I can see smoke rings coming out of my exhaust that smell like coolant and after about 30 minutes of riding, my radiators are almost totally dry. At first I thought it was boiling over, nope, the hose is completely dry and nothing dripping out of it, nonetheless, I put a new 1.3 cap on it. Any Ideas? Share this post Link to post Share on other sites
the white stallion Posted April 7, 2010 Man if you can see smoke and smell colant,you better check your oil. You need a head gasket and check the cylinder and head for warping. Share this post Link to post Share on other sites
Jordanmaxx Posted April 7, 2010 The oil appears to be okay, not milky or anything. Im wondering though, on the outside of the head, on the right side, directly underneath where the main coolant hose is attached, there is a hole? it doesn't appear to be threaded and I can stick an ice pick into it well over an inch? normal? Share this post Link to post Share on other sites
crf250r985 Posted June 8, 2010 yea 99% sure you should probably have your head gasket replaced... and yea good idea to check for warp Share this post Link to post Share on other sites
D-K Posted June 8, 2010 The oil appears to be okay, not milky or anything. Im wondering though, on the outside of the head, on the right side, directly underneath where the main coolant hose is attached, there is a hole? it doesn't appear to be threaded and I can stick an ice pick into it well over an inch? normal? Replace the head gasket. The hole leads in to the spark plug well. You don´t need to worry about it. Share this post Link to post Share on other sites
asg5265 Posted June 8, 2010 engines run real well when they get a little coolant in them, just look at chad reed when he raced indy on that coolant drinking yamaha, thing ran like a bat out of hell. Its a shame he lost...That coolant will eat a nice hole right through that soft aluminum head because coolant is extremely abrasive, so dont run your bike till you fix the problem Share this post Link to post Share on other sites
crf250r985 Posted June 9, 2010 engines run real well when they get a little coolant in them, just look at chad reed when he raced indy on that coolant drinking yamaha, thing ran like a bat out of hell. Its a shame he lost...That coolant will eat a nice hole right through that soft aluminum head because coolant is extremely abrasive, so dont run your bike till you fix the problem Huh thats cool... well not in his case lol but i never knew that Share this post Link to post Share on other sites
Pr1malR8gw Posted June 9, 2010 Coolant in the combustion chamber will cool it down and will create steam which will blast carbon build up off. This in term will increase power if the amount of coolant is neglidgable obviosly to much will well decrease power. Look up water injection on turbo cars some day. Share this post Link to post Share on other sites
