1996 YZ 80 problem. Please help if you can.
Hi i bought a 1996 YZ 80 that had a broken lay shaft. So i split the case and replaced the lay shaft by the book and put everything back together. It shifts through all of the gears fine but now i notice that when the bike is in gear and you pull in the clutch you cant spin the front sprocket? Did i assemble the clutch wrong? It doesnt seem to be internal, at least i hope not. I am hoping it is just the clutch itself. I have not fired up the bike yet to see if i can put in gear and see if it stays put when i pull the clutch in. But shouldnt i be able to spin the front sprocket while it is in gear with the clutch pulled in? Any help or advice would be greatly appreciated. Thank you.
