How to Install LED tail light
probably an hour or less to fit everything up nice.there's only 3 wires iirc.tail light,brake light and ground.i reused the original wire harness and connector and spliced it into the edge's pigtail.crimp,solder,heat shrink then cover with vinyl loom.bolt it to the existing subframe holes with rubber washers in the kit.
3 Wires....so easy...even a monkey could be trained to do it.
Pretty hard to screw up. You will have 1 ground...and 2 hot wires. 1 hot for lights, and 1 hot for brake lights. Try them...if they don't work right...you probably have them reversed.
