How will this base stack perform?
Hi All,
Please take a look on the stack listed below. What is the effect of pulling the 14's? Will this take the hole stack closer to the plate and not letting the shims deflect so much as they will touch the plate? Clamping with 13 will make the stack softer I assume. Adding the LSC stack will make the comp. stiffer in top of the stroke or? It will have a effect on the clickers (bleed) and I assume the clickers biggest effect is in top of stroke.
Std.
32-0,11*21
30-0,11*1
28-0,11*1
26-0,11*1
24-0,11*1
22-0,11*1
20-0,11*1
18-0,11*1
16-0,11*1
14-0,20*8
Plate
12-0,20*4
Revalved
32-0,11*18
30-0,11*1
28-0,11*1
26-0,11*1
24-0,11*1
22-0,11*1
20-0,11*1
18-0,11*1
16-0,11*1
14-0,11*1
13-0,30*2
Plate
11-0,25*2
14-0,11*1
18-0,11*1
22-0,11*2
Bang
i dont think the stack will deflect much so it wont bend over the clamp when its a 13, it will be softer but a decent amount,
having the bleed stack fitted should make the bike dive a little less considering the base is now softer, hard to say overall which one is better, i would suspect for me the 2nd one is.
Hi All,
Std.
32-0,11*21
30-0,11*1
28-0,11*1
26-0,11*1
24-0,11*1
22-0,11*1
20-0,11*1
18-0,11*1
16-0,11*1
14-0,20*8
Plate
12-0,20*4
Revalved
32-0,11*18
30-0,11*1
28-0,11*1
26-0,11*1
24-0,11*1
22-0,11*1
20-0,11*1
18-0,11*1
16-0,11*1
14-0,11*1
13-0,30*2
Plate
11-0,25*2
14-0,11*1
18-0,11*1
22-0,11*2
Bang
I think you would be better off pulling 2 face shims and maybe the 26 and 20 so you don't end up with a harsh spike in the mid stroke but it's hard to say without knowing what you are trying to acomplish. Your face shims will have a greater overall effect than your clamp.
