06 Honda CRF250R Exhaust Pipe - Spark Arrester Help!
Check out a MRD system. They are made by hand and have a totally sweet look when on the bike. Plus, you can either have a single or duel setup as well as having the power band adjusted for what ever you want. Meaning, if you want more mid to top-end, or more low to mid range, or total mid range with good over rev, or.... I think you get the point.
http://www.mrd-racing.com/
or a TT thread
https://thumpertalk.com/forum/archive/index.php/t-658686.html
or a TT thread
I also heard that their warrantee is second to none! If you end up going to an 05 stock system, the mounting bolts won't line up on the 06 subframe. To do it right, you'd need an 05 sub frame. If you order a MRD single for the 06, it's a perfect fit on the existing sub frame.
