AP MOD Leak Jet
I have been doing alittle research on the ap mod, and it sounds like a pretty awesome idea, and I would love to try it. Can anyone tell me what the best size Leak jet to use at 5500ft above see level is, I know alot of guys are saying 90 or 100, maybe? Also how do you set the AP Timing GAP. Do I just set it to .100" like the AP MOD instructions said? Any help on this would be great. Thank you
Thumperfaq can explain it better than I can, so I give credit when credit is due. "The AP provides a “squirt” of raw fuel into the carburetor venturi when the throttle is wicked. It richens the mixture to run best at lower speeds, yet allows a leaner top end for more over rev. This system has a jet called the leak jet which controls how much of the AP squirt is redirected back into the float bowl instead of into the carburetor." So essentially, the leak jet is there to redirect unneeded fuel that the accelerator pump pumps in and puts it back in the float bowl when the engine is at higher rpms. I am sure someone will correct me if I am wrong.
wire it tight.....put a 90 in and a 05 crf250 diaphram......or shave the stock one down to 2mm......this mod is so badass on my 03....what year you have?
I have an 06, so the 90 leak jet is fine for my elevation?? I cant wait to do this mod!!!👍 alot of guys say how much it helps, Also will I have to change the jetting or anything else on the carb, and Im a bit confused with the AP Timing Gap. How am I exactly supposed to set this?? thanks for all the help!
Edited by kjwcoyote88
perfect, thank you very much. I know exactly what he is talking about. +gas to you
Can you use an adjustable leakjet with the mod?
Thats a great question?! Does anyone know if that will work??? As far as I can tell the R and D Power Pump 2 adjusts to the equivalent of a #10 through #70 leak jet. Can anyone confirm that? Also, where on earth do you find a #90 leak jet for this mod, Im having a hard time finding one.
