fitting mrd/ssw
HI all im in the process of fitting my mrd ssw i took the old exhaust (stock)off and there was no gasket in the pipe at all connecting header to engine am i right to think this is not normal.
has any one got any pics of these gaskets
also will i need a gasket to connect the header pipe to the exhaust on my mrd/ssw
thanks for your help fellow DRZ ers 👍
Typically the gasket is stuck in the port. It is silver in color and hard to distinguish from the aluminum surrounding it.
It does not typically need to be replaced. If it were gone...you would definitely notice as the pipe would sink and extra qtr inch or more into the head causing obvious fitment issues.
