650RACER Posted April 8, 2010 I have the stock triples and Pro tapers on the bike but feel more and more like the bars are too low. Naturally I want to try a higher bar but would like to try bar risers first before buying a different bar. less money to try it out. problem w/ most bars is to get a flat sweep or near the stock pro tapers now you only gain a small amount of height. Anyone know where to get bar risers in various heights?? the Tusk version that would fit my bike raises over an inch. thats going to be too much. Thanks Share this post Link to post Share on other sites
nuudle8 Posted April 8, 2010 Did you try RoxSpeedFX ? They make a variety of bar risers, I had got some for one of my wife's quads. Share this post Link to post Share on other sites
mtdirtbag My Ride Posted April 8, 2010 If you're going to be adding a stabilizer, I have a Scotts undermount set-up I'm trying to get rid of. Fits the stock upper triple and raises it approx 3/4 of an inch. Share this post Link to post Share on other sites
650RACER Posted April 8, 2010 If you're going to be adding a stabilizer, I have a Scotts undermount set-up I'm trying to get rid of. Fits the stock upper triple and raises it approx 3/4 of an inch. Already run the GPR fastway Fit setup otherwise I would entertain that route. Thanks Will try Roxspeed FX Any other suggestions? Share this post Link to post Share on other sites
650RACER Posted April 8, 2010 Did you try RoxSpeedFX ? They make a variety of bar risers, I had got some for one of my wife's quads. No dice Share this post Link to post Share on other sites
Luv2crash Posted April 8, 2010 You could probably find the right stuff at your local hardware store. Or for me instead of risers i just tried a new bar bend that was the same height but had less sweep. Less sweep would and did move the the bars a touch higher simply because the top clamp is at an angle, so forward a little bit IS higher too. Share this post Link to post Share on other sites
bloodline Posted April 8, 2010 http://www.rockymountainatvmc.com/productDetail.do?navType=type&webTypeId=70&navTitle=Handlebars-Control&webCatId=12&keyword=BAR+RISER&prodFamilyId=25849 Share this post Link to post Share on other sites
dirtdan Posted April 8, 2010 No dice Why, No dice ? I have the pivoting types and they are great, you can see them in my garage. http://www.roxspeedfx.com/cgi-bin/cart/showitems.cgi?subcat_id=256 Share this post Link to post Share on other sites
nuudle8 Posted April 8, 2010 Why, No dice ? I have the pivoting types and they are great, you can see them in my garage. http://www.roxspeedfx.com/cgi-bin/cart/showitems.cgi?subcat_id=256 Yeah I thought that they would work with any handlebars? Share this post Link to post Share on other sites
650RACER Posted April 8, 2010 Why, No dice ? I have the pivoting types and they are great, you can see them in my garage. http://www.roxspeedfx.com/cgi-bin/cart/showitems.cgi?subcat_id=256 First post "the Tusk version that would fit my bike raises over an inch. thats going to be too much." Thanks for the suggestion though. Bought factory Suzuki KTM less sweep bars and slightly higher and will try that. might have to get creative if i need a little more height. Share this post Link to post Share on other sites
Luv2crash Posted April 8, 2010 First post "the Tusk version that would fit my bike raises over an inch. thats going to be too much." Thanks for the suggestion though. Bought factory Suzuki KTM less sweep bars and slightly higher and will try that. might have to get creative if i need a little more height. Not sure what brand you bought, but i too just bought the KTM bend from Sunline. Motosport.com had a closeout on them. Did 50 miles on them Sunday. One of the best purchases i've made actually. I've found with handlebars that a few mm's can make a big difference in feel. Share this post Link to post Share on other sites
650RACER Posted April 8, 2010 Not sure what brand you bought, but i too just bought the KTM bend from Sunline. Motosport.com had a closeout on them. Did 50 miles on them Sunday. One of the best purchases i've made actually. I've found with handlebars that a few mm's can make a big difference in feel. Sweet! Love hearing that kind of feedback post purchase pre trying the part out! What dimensions are yours do you know? I went w/ the pro taper contour again. Share this post Link to post Share on other sites
spinner38 Posted April 8, 2010 have you tried them one inch higher? i used the rox risers on mine and moved them one inch forward and up, then set the rake of the bar the same as the forks. turned out nice, not too tall and keep the bars over the triple clamp. also made the steering not so edgy. i am about 5 9 and with this set up the bike works better for me in every aspect. i am only trailriding though 👍 Share this post Link to post Share on other sites
Luv2crash Posted April 8, 2010 KTM bend 808mm wide 95mm high 70mm rise 38mm sweep According to them the Henry/Reeds(what i used to have) are.... 805mm wide 93mm high 50mm rise 55mm sweep Share this post Link to post Share on other sites
hackman162 Posted April 9, 2010 Ride Engineering makes 10mm risers that bolt underneath the bar mounts. Share this post Link to post Share on other sites
650RACER Posted April 9, 2010 Ride Engineering makes 10mm risers that bolt underneath the bar mounts. Thanks man. I googled the site and it seems all they have are crf parts?? Am I missing something? Have a link? Thanks! Share this post Link to post Share on other sites
