jaymc637 Posted April 8, 2010 I just got done rebuilding my 05 motor & I put on a FMF powerbomb system when I started it up & Idled for about 5 min i realized the header pipe was starting to turn cherry red about 2 inches out of the head is this normal or did I screw something up? Share this post Link to post Share on other sites
mxn4life Posted April 9, 2010 Not to wory, completely normal.👍 Share this post Link to post Share on other sites
snb73 Posted April 9, 2010 Adjust fuel screw, 1/8 of a turn makes a big difference. But as said before, the header does get a bit hot. Share this post Link to post Share on other sites
garrettstump Posted June 7, 2010 run engine ice for coolent, it helps Share this post Link to post Share on other sites
reloadz400 Posted June 7, 2010 Want to know a good trick for checking your jetting? Take a ride after dusk, find a place to safely pull 4th or 5th gear to the limiter, and glance down to check the glow on your pipe, depending how far down the glow is will tell you how lean/rich you are running. As stated above, glowing is 100% normal. Share this post Link to post Share on other sites
