Yamaha 660 Griz lean ????
Just finished a 660 grizzly and found the valves were way out . So I set them and cleaned the carb and Ran great the first night ! Then when I went out tonight it's poping and bucking and stalling ! Plus the pipes are getting red !!? Recleaned the carb but no help. Think the valves are to tight ?? Any help would be great. It's definetly to lean!!
If it got cooler during the night then yes it is lean, Might try adjusting your air/fuel screw 2 3/4 turns out and see how it reacts to the change. If no change then get a bigger Pilot Jet.
Got it rite !! Some A/hole tryed to redo the carb and put the wrong washer undewr the needle jet .PLUS the intake was warped real bad and it was sucking air past the O roings underneath. Thanks for you input !!
Glad you found the problem, a warped intake can cause problems.
