2002 xr100
Recently purchased xr100. Start first kick. Idles fine when cold but after warming up it will not respond to quick throttle opening. Idle speed maintains correctly for 30 seconds or so and then slowly dies. All indications of lean mixture. A little starting fluid squirted around the choke shaft and the rpm raises slightly. Is there a cure for this problem or will it require a new carb?
recycled-cycles32
