Bad bog...jetting?
I have an 07 KX250F and it has a pretty bad bog even with it fully warmed up. I have the stock exhuast and the stock jetting in the carb. I have a boyesen quickshot and the fuel screw is at 2 turns out. I have had the fuel screw out as much as 3 and it seems to do nothing. I also checked for air leaks around the carb boots and cleaned out the hot start plunger to make sure it wasnt sticking, everything is good. Not really familiar with jetting and thought I would get some recomendations on what jets to use, thanks.
