Jefred Posted April 9, 2010 I have got a problem with my DRZ400SM. When riding in heavy rain the engine is cutting off. The heavier the rain is the worse it gets. I have tried to house the bike water while running and it runs fine. Once in a heavy rain I stopped at a servo, took the tank off and everything seems more or less dry. I too all the electrics apart and sprayed it with some "connector" spray (not sure what was the name) but no improvement either. Also it seems to me the engine is cutting off (just a little) at high revs when dry. Any idea what might be causing this problem? Faulty (cracked) coil or something like that? The electrics is all stock. Cheers Share this post Link to post Share on other sites
guiri Posted April 9, 2010 I don't know a damn thing about bikes but if you hose it down while running and nothing happens but you ride and it cuts off, that to me suggests that whatever the problem is, it's underneath. George Share this post Link to post Share on other sites
Boulder1 Posted April 9, 2010 Take the breather hoses up under the tank or up along side airbox. I have left only the hose from the bowl down and dont have any probs with water. Share this post Link to post Share on other sites
Devondan Posted April 9, 2010 Have you tried running it at night in the dark to see if the HT circuit is arcing? Simple things first check the plug cap, plug and the drain hole in the head, the plug hole could be filling with water? Dan Share this post Link to post Share on other sites
SoylentGreen Posted April 9, 2010 I had the same problem last summer. I thought it might be water running off the tank into the 3x3 hole. It only happened when the rain was pouring down hard. Share this post Link to post Share on other sites
Jefred Posted April 9, 2010 I have changed the plug, the drain hole is OK. I have also tried to run it in dark, trying to arch the circuit but could not see anything. I thought it is a dirt bike, so there should not be a problem with the breathers? I might try to run them somewhere else anyway. Thanks guys Share this post Link to post Share on other sites
Devondan Posted April 9, 2010 I doubt its the breathers unless you are running in water 2' deep! They can cause a prob if they "suck up" water which is why many route one from each side under the tank. Have you tried spraying the electrics in WD40, if it improves you know its electric. You could have a coil prob but to be honest most Zs are fine in the wet. Share this post Link to post Share on other sites
JoelH. Posted April 9, 2010 I'm just spit-balling here! Could it be, water in the kill-switch, water in the kickstand switch, in the clutch switch (if you have them). Other than that my only advise is, spray everything electrical down with Teflon Dry Lube (the kind that's just Teflon and propellant not wax). It's not at all messy like WD-40. Share this post Link to post Share on other sites
tiemann1 Posted April 10, 2010 About a year ago or so my KLX400R started going dead in the rain also. I moved the ignition switch from the handle bars to a vertical position to prevent the water from entering the keyhole. Problem solved, Share this post Link to post Share on other sites
Jefred Posted April 10, 2010 About a year ago or so my KLX400R started going dead in the rain also. I moved the ignition switch from the handle bars to a vertical position to prevent the water from entering the keyhole. Problem solved, I might try that. Yes I pulled all (at least I think) electrics apart and sprayed with some kind of dry electric spray. Don't remember name anymore. Keep the ideas coming. Share this post Link to post Share on other sites
Devondan Posted April 11, 2010 It would probably be helpful to list all the things you have tried? Otherwise we are going to be suggesting things you have tried already. Can you repeat the problem with a hose? if you can have you tried bypassing the sidestand switch? Thats a PITA that can go IMHO anyway! Share this post Link to post Share on other sites
Moat Posted April 12, 2010 I don't own a DRZ400, but - If the DRZ has a single float bowl vent hose that empties underneath the bike, your problem could be similar to what is common with KLR650's (and other bikes) - the "T-Mod" adds a second vent hose under the seat area, preventing water from temporarily plugging the atmospheric vent and causing erratic running/stalling in the wet. Quick, simple, cheap - might be worth a try... http://www.klr650.marknet.us/tmod.html Share this post Link to post Share on other sites
