Starter button intermittent?
Hi I bought an 06 drz-400sm recently (a month) and just today it started bugging out when trying to start the bike. I turn the key on, pull the clutch, kill switch is set to ON but when I push the start button nothing happens. I just keep pressing it and release/pull the clutch and again and then it will randomly just work. Any ideas?
The only thing I can think of causing this random problem all of a sudden was that it got soaked by a sprinkler when I was in the gym for about 30mins so maybe some water got into the electrical? I have no idea! ­čĹŹ
Thanks,
Sam
Several people have reported bad solder joints or bad contacts in the start button. Clean and repair. Also could be a bad clutch interlock switch. Just bypass it. Follow the wires to the bullet connections, pull apart and reconnect to bypass the switch.
├Ś
├Ś
